Dome Size advice - Forno Bravo Forum: The Wood-Fired Oven Community
Dome Size advice
  • Dome Size advice
    I have a 60 x 60 inch concrete stand in the corner of my patio. My patio has a brick knee wall all the way around it's perimeter. Currently the knee wall only comes half way up the stand. I plan on adding more courses to the knee wall and two more walls to enclose the stand and oven, effectively making the stand 71 x 71 inches outside to outside measurement. What is the largest size Pompeii style oven (non corner install) that I can put on the stand? iI would like to to at least 3 inches of extra cladding and use 2-3 inches of FB blanket on the dome, finishing by filling the enclosure with vermiculite. The enclosure will have a gable type roof. Thanks for any comments, suggestions, or ideas in advance
    ______________
    I talked to a calzone for fifteen minutes last night before I realized it was just an introverted pizza. I wish all my acquaintances were so tasty.
    Jarod Kintz
    http://www.fornobravo.com/forum/f6/n...ona-20937.html
    Google + Link to my build
    Re: Dome Size advice
    Just like jeffrorrt, I too am starting up my outdoor pizza oven project myself. I have a 48x48 inch base, any info on recommendations on dome diameters and sizes would be much appreciated!
      I suggest a 42" oven. NCMan told me that he'd sent his IT to you...that came from me, and previous to that, from Kurtloup! Best wishes on your build.
      Link to my build
      http://www.fornobravo.com/forum/f8/4...nia-19904.html
      Link to my pictures
      https://plus.google.com/photos/10871...CPfMh4SMmcnQAQ
        Thanks! Check out my progress under New build in SW Arizona
        ______________
        Jarod Kintz
          If you have a stand and want to build a dome, here's a quick calculator:
          - the oven walls are normally 4.5 inches thick so that is 9 inches total
          - you'll want at least 3-4 inches of insulation. Let's say 4 so that is 8 for both sides
          - you need some kind of enclosure, let's say that is 1 inch thick so 2 inches all together.
          - In total that is (9+8+2=19 inches)
          So the max dome size you can have is x-19, where x is the base size.
          For a 48 inch stand this gives a 29 inch oven
          For a 71 inch stand this gives a 52 inch oven - way bigger than you will ever need!
            Thanks B,
            I went wih a 39 inch
            Jeff
            ______________
            Jarod Kintz
