Up up and away (dome)
  • #31
    Re: Up up and away (dome)
    Alright! Hope to have pictures of a finished
    Dome today. Next will be the arch and flue
    Opening. For a 42" is 6" opening enough?
    Being in the arch the opening will be rectangle.
    What size did you guys find lent to a good draw?
    • #32
      Now to start on the front arch and flue.
      • #33
        Congratulations on your pluggin' Bubb. Bet that's a good feeling, getting that done.
        My Build:
        • #34
          G'day Bubb
          Great to see that final keystone in position. It's always a great feeling.
          In answer to you questions. Yes you could build a square entranceway, but you got the skills, why not an arch? They are stronger anyway. I would make it big its better to operate you oven through a larger entrance. As for a 6 in pipe being big enough, no, you'll need a 8 in for a a 42 in oven. Do make a smoke chamber above the oven mouth as wide as the mouth so it will collect the smoke and then funnel it in to the pipe. If you do this none of the smoke can bypass that 8 in pipe and will go up that chimney.
          Hope something here helps
          • #35
            Great job Bubb! I can smell pizza cooking soon. Congratulations on your plug.
            Chris
            Link to my photo album:
            • #36
              CobblerDave yep I'm doing a arch. Could you
              Explain what a smoke chamber is? Is that a wider
              Opening at the bottom tapering into the flue? Can I
              Use regular brick for a flue with home brew mortar?
              This is the front I want to do.. Trying to deside if they
              Used a tericota pipe and bricked around it?
              • #37
                G'day
                http://www.fornobravo.com/forum/21/4...tml#post148793
                Sorry I'm on holidays at the moment and only have the phone.
                This link, if I have it right will put you about page 21 of V-Wizs build its got some good pics particularly the one showing the smoke chamber in front of the oven mouth nice and wide so the smoke can't bypass it and tapered so it funnels it into the chimney proper.
                There's no problem in using ordinary brick on your oven entrance chimney area in fact when you consider how plane and ordinary firebrick is, it gives you a chance to make a bit of a statement.
                Hope this helps with your decisions
                • #38
                  That was perfect!!! It gave me all the answers
                  I needed! I'll do flue and first course in fire brick
                  Then go up regular brick... Thanks so much Dave.
                  Wish I could repay you in pizza! ��
                  • #39
                    CobblerDave from the pics you gave link to
                    I made my smoke chamber. I cut as big as I
                    Could but wanted enough shoulder for strength.
                    Now laying up face
                    • #40
                      G'day Bubb
                      Your powering ahead.... Looking good
                      Oops, there was an error! | UK Wood-Fired Oven Forum
                      Here's another oven that might give you some ideas. JMS has done a great job and is on the home stretch. I hope that you can access the UK forum if not give me a heads up and I'll do a search he also has it on the FB site but I just couldn't find it at this time
                      • #41
                        G'day Bubb
                        http://www.fornobravo.com/forum/f8/3...=Scottish+oven
                        Here it is enjoy
                        • #42
                          Finished arch way last night. Starting chimney today
                          Really happy with progress so far. I'm not doing too
                          Bad for never laying brick before.
                          • #43
                            G'day
                            Well what can I say ....WOW! ....... Mate...that is one good looking entrance.
                            Well done!... Now that's a statement
                            • #44
                              G'day again
                              Just love that keystone...
                              • #45
                                Bubb, I agree with Dave.
                                Great work! Try uploading smaller pics in your future posts, so I can see the Like button .
