Up up and away (dome)
  • #46
    Re: Up up and away (dome)
    Thanks guys.. I can only do one more course
    Today. Then I need to do insulation and stucco.
    I want to make sure I blend chimney in with arch
    Of the stucco. So I gotta do that next I think. I
    Only have one 50' roll of 1"x12" blanket. I'm
    Planning on 3" so I'm going to ball park guess I'll
    Need two more rolls. That is a pretty big dome..
    • #47
      Getting ready to start stucco. Might get a coat on tonight...
      • #48
        G'day Bubb
        Looking good! Are you still planning to do the brick over the dome as in that pic you posted? How much CF blanket did you finally achieve over the dome. It certainly turned out pretty smooth for blanket.
        • #49
          Dave I got 3" on and wire. That's first coat
          And I ran out of light. The file pic I was using
          I just liked the front entry way. I'm not doing
          Double brick just stucco. Saturday I'll finish
          Stucco nice and smooth. The Monday I got
          All day weather permitting to work on the
          Chimney. I'm scored free stone for covering
          The base. I get this done end of the week
          I'll start my little curing fires..
          • #50
            • #51
              G'day Bubb
              3 in of blanket is worth 6 in of pearlcrete in insulation value they say so I think you got that well and truly covered. There is something to be said for using 1/2 inch as its easy to keep it smooth I would hate to wrestle with 1 in.
              The dome pretty smooth with the first layer do you can only improve on that. You might consider to use an acrylic render layer for your last layer as its more water resistant and resident to expansion and contraction. The local products sorry Ill leave that up to you.
              You have got to be happy thus far that's looking very smart
              • #52
                Dave I did industrial insulation younger
                In life and have a neat installation stapler
                That almost stiches insulation. I'm planning
                On a roof to keep weather off. So one maybe
                Two more layers of stucco I'm sure it will be
                quit smooth round. Really bighting at the bit
                to finish chimney. Have some design features
                In mind for that. Went to a local collage and
                Looked at the brick work. Great place to get ideas
                Things that are easy to do, but give the most pop!
                Hopefully I'll be on that by Monday.
                • #53
                  Stucco done! Didn't go perfectly smooth, wife
                  wanted a little texture for looks. Now I'm on
                  Finshing the chimney. Base is scratch coated
                  ready for stone.. Man I can't wait to fire this
                  thing up.
                  • #54
                    Finished chimney, and all stone work.
                    Working on counter top.
