32" build in north TX Insulation question.
  • Brave
    Re: 32" build in north TX Insulation question.
    I don't think you'll get much compression with either product. If you're concerned with the insulation property I think you'd be better off increasing the thickness just to be sure.
  • Tonyp
    If I am not mistaken the properties of CaSi board vs AlSi (ceramic) are essentially the same. So I would go with whatever is cheaper for you. It seems like a lot of weight but it is spread over a fairly large surface area and evenly around the perimeter of the oven. It's difficult to compress the stuff.. I tried by smacking a few proud floor bricks with a rubber mallet..
  • strobes
    yes, I'm trying to figure out which board will compress less ( effectively reducing thermal insulation) while been sandwiched between the oven and support slab. I'd estimate oven's weight about 1400lb. and of course most of it will be on edges of the board.
  • Tonyp
    What do you mean by support weight? Either one will be fine under the weight of a 32". They are not structural though and must be laid on top of a support slab.
  • strobes
    started a topic 32" build in north TX Insulation question.
    CalSil or Ceramic fiber Board? Will either one support weight of 32" oven? Which one is more cost effective?
