Heat profile of the "as designed" oven - Forno Bravo Forum: The Wood-Fired Oven Community
  • Heat profile of the "as designed" oven
    Has anybody done a fair scientific heat profile on the pompeii oven as it is designed in the ebook? I would like to see one with at least a thermocouple embedded in the cooking surface and one within 1 inch of the dome surface and while I'm dreaming here one on the dome outer surface. Fire to a clean dome and then plot temperatures to time and get a graph.
    I want to know if the as designed oven will give me at least 2 hours in the 425F to 350F range.
    --mr.jim
    --mr.jim
    The real art of conversation is not only to say the correct thing at the right time, but also to leave
    unsaid the wrong thing at the tempting moment.
    Re: Heat profile of the "as designed" oven
    All right another geeky engineer. Do a seach on "probes" and maybe another on "Temperature profile" About a year or two ago somone poseted some detail graphs of temperature and time for firing up the oven and cooling down.
    Also consider slow cooking where your cook for a longer time at a lower temperature., With the food product (meat) covered by foil it will still be quite moist. if you are thinking bread then you may need to charge the fires to a slightly higher temp, steam the oven with a sorayerand then toss in the dough.
