Pompeii PDF Plans vs. Website plans - Forno Bravo Forum: The Wood-Fired Oven Community
  • Pompeii PDF Plans vs. Website plans
    Hello,
    I'm studying everything with a fine tooth comb before I begin work on a 42" Pompeii.
    I noticed the website and PDF materials lists show dimensions of:
    Foundation - 80" x 94"
    Block Stand - 72" x 84"
    Then on p.13 of the PDF and
    http://www.fornobravo.com/pompeii_oven/foundation.html
    The recommended dimensions are:
    Foundation - 77" x 86"
    Block Stand - 69" x 76"
    Why are they different? Is this an oversight, slightly different design or am I missing something?
    Cordially,
    Ken
    Ken H. - Kentucky
    42" Pompeii
    Re: Pompeii PDF Plans vs. Website plans
    I think, It's not exact, but 72 and 84 are both divisible by eight. The actual measure of a concrete block is not 8 by 16, but 7.5 by 15.5 I think one may be a mortared dimension, and the other a dry-stack dimension. 4 and a half times 15 and a half is 69.75.
      Based on some recent discussion on some of the threads here your other option is to build it slightly big. You can always make a smaller floor and dome and have room left over for insulation. It is a bit trickier when you near the end and realize that you are tight space wise
        Thanks for the responses. I like the "build it slightly bigger" approach. Seems like I can design a block layout that will involve less cutting.
        I'll try not to make rocket science out of this and keep it simple!
        Ken
        Ken H. - Kentucky
        42" Pompeii
          "dc-8-61"
          Last edited by jengineer; 07-16-2007, 10:19 AM. Reason: hey why does it mkep making the c lower case?
            Originally posted by jengineer View Post
            "dc-8-61"?
            DC-8-71 or 73 (UPS)
            Ken
            Ken H. - Kentucky
            42" Pompeii
