Insulation Board - Forno Bravo Forum: The Wood-Fired Oven Community
Insulation Board
  • Insulation Board
    I recently bought a box of insulation board (Durablok) from my local refractory, but wanted to check here first to see if it was ok for use with my oven. The board is quite rigid, and the compressive strength seems to be ok as long as the pressure is spread out...i.e. I could probably deform it somewhat by pinching both sides with my index and thumb, but I doubt it would deform if I stood on it. Also it cuts easily with a box cutter. Is this normal? I was also thinking of adding another layer of either this board or the superisol to give 4" of board insulation. Anyway I've attached the datasheet of this board for your review. Thanks for any comments or direction!
    Oven Progress
    Bread Photos
    Oven Stand Thread
    Re: Insulation Board
    Not being a chemist or engineer, I can only say it seems to be a suitable substitute for the SuperIsol, based on reading the data sheets of both. If the price and availability are right, go for it.
      I'm OK with that as well. Builders have used both Cal Sil and Alu Sil board underneath their ovens, and they both seem to work well.
