Foundation guidance - Forno Bravo Forum: The Wood-Fired Oven Community
Foundation guidance
  • Foundation guidance
    Where did you all find your guidance for depth of foundation? I'm in atlanta, so frost line is not really an issue.
    Re: Foundation guidance
    I found out from several sources: Les, whom lives in same region. H.D. pro desk, and a local builder that needs to know the frost levels for building homes. All said that extreme freeze is what one looks to get below. For us, the extreme cold can get to 18 inches, therefore I went to 2 feet.
    For you, contact a contractor or two, your local H.D. or Lowes (pro desk) and local FB friends. Take all information and you will know the proper depth.
    Acoma's Tuscan:
      To add to this; the type of soil is very important. I?m sitting on D.G. so there is very little, if any, soil heave. If you?re sitting on clay I would dig down a bit. Like Robert suggested, contact someone who is in the know for your area. It will probably be overkill but what?s the harm.
      Les...
        I've got a frost line of 2 to 4 inches. The thing that is killing me is that the building inspector is telling me I need to be 12" deep, as he says that is the minimum allowed for by the IRC (international residential code)
          You're not pulling a permit for this are you? Going down 12 inches sounds pretty reasonable for the footings. You don?t need the entire slab to be 12 inches thick.
          Les...
            I'm on the fence about the permit. I spoke with a structural engineer who was surprised I would consider going through the permit/inspection process.
            It is an outdoor kitchen with power, gas, and a fireplace.
            I called up the permit office and generically asked them why if I can just proceed without a permit or inspection and they mentioned that it could cause hassles when I try and sell my house some day.
              Not a bad idea to pull a permit and go through the inspection process for what your planning, unless you have personal experience with utilities. Gas and electric are both dangerous if done incorrectly. If your hiring out the job, an even bigger reason to have it inspected - I've learned to trust no contractor here in FL, even the best sub things out to cheap and inexperienced labor.
              RT
                Generally speaking, once you start installing utilities, you need a permit.
                The actual rule, from memory, is less than 50 square feet, less than 10 feet tall, no utilities: no permit. It's a shed exemption, which also covers things like backyard barbeques and pizza ovens.
                For the foundation, either one of two things. Either you pour a slab on a base of well drained crushed rock, where the structure in essense floats over the soil, or you dig down below the frost line and pour footings directly on the undisturbed sub-soil. If you do footings, it's only around the edge, the whole slab doesn't need to be that thick.
                And I second RT's suggestion, that if you're using a contractor, you want the inspection before you make the final payment. That's the law here, and it's for your protection.
                  What's a frost line? (kidding). While we pay 3X for firebricks having the annual temps 60-92 ain't all bad.
                  That shed exemption varies by area as well. Ours was 100 ft2 and was increased to 110 or 120 IIRC so that people didn't have to pull permits for garden sheds.
                    Get a permit.
                    You may void your house insurance if an accident is related to an un-permitted structure. Send a fax or email of what you are building to the building inspection staff. If a permit is not needed, then you will have a record of that fact as well.
                    The permits cost next to nothing and you can also get good advice from your local building inspection staff.
                    If you are ever told by a contractor that "we don't need no stinking permit" - get another contractor.
                      I've read that elsewhere as well and now plan to have it inspected. Can't wait to start!
