liquid to harden insulation blanket?? - Forno Bravo Forum: The Wood-Fired Oven Community
  • liquid to harden insulation blanket??
    Hi
    A local modular kit uses a product (no idea what it is) to spray onto the insulation blanket to harden it so as to allow the stucco to hold without using straps/chicken wire. Anyone have any thoughts on this? Would the hardener reduce the insulation effectiveness?
    Thanks.
    Re: liquid to harden insulation blanket??
    This is the stuff, or something like it. At thirty four bucks a gallon (I don't know what the amount needed is) you can buy a lot of chicken wire. Many people use a layer of perlite/vermiculite concrete on top of the blanket to increase insulation and create a rigid, smooth layer for the stucco. Remember: the blanket doesn't go on in a smooth hemisphere, it's all bumpy and lumpy from bending and overlap. In any event, the people who sell it will know if it affects the insulating properties of the blanket.
      May be these pics could help with the answer...
      Luis
