View Post
So if I understand the hardibacker. Is the difference between plywood and backer that you don't need to have the hardibacker sheets a half inch below the level of the top layer of cement blocks? In other words, you can just span the width of the stand by supporting underneath? In this configuration I see that the backer is not counter sunk but sitting on top of the stand and extending over the inner edge of cement blocks by a few inches.
Mike
