Dry stacked vs. Mortar - Forno Bravo Forum: The Wood-Fired Oven Community
  • Dry stacked vs. Mortar
    What is the benefit of dry stacking the blocks for the stand as opposed to mortaring them?
    Mike - Saginaw, MI
    Picasa Web Album
    My oven build thread
    Re: Dry stacked vs. Mortar
    I think it's just an easier construction methos and you still have the foundation strength needed with the filled cores....
    anyone used single sized blocks in a rounded pattern?
      The whole pompeii oven project is designed for people who never mixed mortar before. Stacking blocks and filling is something anyone can do - If you don't like how it looks, or something isn't level, you can go back and restack them before you fill the cores. Mortaring cement blocks is a difficult thing to do. You are basically setting up a thin rim of mortar on the edges of the hollow block, unlike a brick, where you are covering the whole flat surface. I built my whole internal chimney with mortared four inch blocks, as well as my internal oven base. It's not much to look at, and now I am covering it with tile. I'm frankly in awe at a mason who can lay up a wall of blocks with smooth even mortar joints. It's a commonplace thing, but it's not easy to do.
        I need to build a block foundation, which will be underground. Since I've never laid mortar before, what are the chances I will be able to come out level on top. I am not concerned about the appearance (I'll bury it all in the end), but it needs to be level. What is the concern about dry stacking block for a below grade foundation? Does it allow too much water to seep in?
        Mike - Saginaw, MI
        Picasa Web Album
