My first WFO design, any comments before I build?
The oven should be there for generations as there's nothing to rust away. A timber stand will deteriorate and move in the weather setting up stresses that might cause cracks in the oven and ultimate collapse from the weight it supports. If it's your only option then I guess it will have to do.
The insulating slab between the reinforced concrete supporting slab and the cooking floor bricks should be 4" thick if using a 5:1 perlite/cement mix, if it is to achieve adequate insulation value.
Thanks I changed the thickness of the perlite concrete design and the wood accordingly.
A timber stand is a poor choice if the oven is to be out in the weather. A masonry stand is permanent.
I understand that masonry would be better, but why is wood that bad? It can easily last 10 to 15 years as I've read, and even more if you treat it. Are there others factors why wood is a bad choice?
Commercial renders contain a waterproofing ingredient which makes them partially waterproof. This allows them to breathe while repelling most moisture. A mix you make yourself does not have this quality. although you can add a waterproof layer over it if you wish.Fully waterproofing the oven will keep moisture in as well as keeping it out.
david s
@fox
Thanks for the advice! I think I will go with the perlite concrete layer with reinforced cement render over it. Is it water resistant when I do it like that?
Last minute question. I'm going to get the wood for the legs now, so I hope I read your answer before I buy them as it affects the height :P. I'm thinking that the perlite concrete layer of 2 inches may be too thin. Should I make it thicker?
Cheers!
Originally posted by Mark1986 View Post
Ok! Would the polypropylene fibers also work? I read somewhere that 1.5% of the volume is the right amount. Would you also go for a reinforced concrete with fibers as a render? Instead of the perlite concrete?
Cheers!
The addition of hydrated lime in the outer render is, I believe, quite important as it imparts some elasticity and self crack repair qualities. (see link I posted in previous post) The outer shell is subjected to higher temperatures than renders in other applications as well as steam expansion pressure, so it needs to be pretty strong. I use a 4:1:1 sand, cement and lime mix. There are plenty of alternative methods to achieve the outcome you’re after.Last edited by david s; 05-19-2021, 03:09 PM.
You must decide what you actually want from your oven, you don’t have to go all out and spend loads of extra money if you just intend to use it for a few friends and family.
If you add all the bells and whistles you will get slightly faster warmup time and longer heat retention but is that really necessary for what you need ?
There are hundreds of wood oven builds on this forum that just use a basic build format because it works well.
However if your budget extends to using ceramic fibre products in place of perlite or vermiculite cement mixes, then it will speed up the build and improve performance … it is just not essential.
I am a bit worried about the floor insulation looking at it now. Will the perlite concrete and firebricks do enough for insulation and thermal mass? Or should I adjust things? Maybe I can use homebrew under the oven floor?
Originally posted by david s View PostBe careful, too rich a mix in cement can cause shrinkage and cracking. Fibres in the mix can also be overdone. Follow the product dosage recommendations. There are many different types of fibres available for use with concrete, mortars and renders. I use AR (alkaline resistant) fibreglass fibres, which I find easy to use and work well. Get them from the concrete countertop suppliers.
https://www.google.com.au/amp/s/alld...mix-ratio/amp/
Cheers!
Originally posted by fox View PostFibres reinforcing for cement products has been around for decades and it comes in many mixes and has many uses.
Where I live it is used extensively in the building trade, ranging from long thick fibres for concrete to ultra find fibres for finish plaster.
You would obviously follow the manufactures recommendations but 2 parts fine sand to one part Portland cement mixed carefully with the correct amount of fibres will give you a very hard a crack resistant casement. It sets like sheet metal and water wont easily penetrate through the high cement content.
My own method is to lay several thin coats of 4-1 find sand mix directly over the ceramic fibre matting, you do this so the weight of a single thick coat will not squash down the matting. Then the next day add your top coat of fibre mix cement, you can lay up to 4” thick without sagging so it is easy to shape your dome how you want it.
The main disadvantage with strong mix, fibre cement, is getting a very smooth finish as ordinary plaster tools leave the fibres standing up.
There are a few ways to get a good finish, one is to manipulate the mix as best you can with a trowel and use a mini paint roller to get a neat finish.
Different rollers with give different textures from smooth to heavily embossed and it is very easy to do.
However for a truly professional finish, you can add a finale top coat of 4-1 cement (no fibres) as soon as your main coat is firm.
So .... day one two thin coats of plain 4-1 ... day two one ‘thick as you wish’ coat of fibre cement and one final top coat or final top coat within 24 hours.
Sorry for all the questions, this is all really new to me!
https://www.google.com.au/amp/s/alld...mix-ratio/amp/Last edited by david s; 05-19-2021, 04:15 AM.
Originally posted by fox View PostSo if your budget would stretch, I would recommend 4”” of ceramic blanket over the dome and a fibre cement top coat rather that a perlite top coat.
fibre reinforced cement is mixed at a 2-1 ratio and is extremely crack resistant and water resistant too.
Also I would highly recommend a 3” ceramic fibre board base under the bricks.
Thanks for your advice! I will see if I can use more ceramic blanket!
What does a fibre cement mixture consist of? It is mixed 2 parts portland cement to.. ?
Thanks in advance!
Cheers
Originally posted by Mark1986 View PostHi all,
This is my first post on this forum, so forgive me if anything is off..
I got enthusiastic about building my own WFO in order to make the best pizza one can make. As I have financial constraints, I had to look for economic WFO designs. I decided to build one, casting over an exercise ball with perlite. It was quite hard finding all the build information in one place, so I gathered it as best as I can.
I am really fond of Sketchup, so I decided to model my build in it. Find the screenshots below.
It would really help me if someone could have a look at my design, and tell me:
1. If the design is good enough to work
2. Are the insulation layers of the dome and floor big enough?
3. Am I wasting any money on materials in my design?
Dome
4" perlite cement inner dome
4" insulation blanket
2" perlite cement render
Floor
2.4" fire brick
4" perlite cement
I am really looking forward to building my first WFO! Thanks in advance!
Cheers,
Mark
Dome
2" homebrew inner dome
3" insulation blanket
1.2" perlite cement render
Floor
2.4" fire brick
2" perlite concrete
4.5" reinforced concrete slab
Stand
0.5" cement fiber board
4" wooden beams
The homebrew will consist of 3:1:1:1 - sand, cement, clay, & builders lime. I will also add some polypropylene fibers to the mixture.
david s: What ratio should I use for the perlite concrete under the pizza oven?
I will upload photos and videos of my build coming week
Cheers Mark
I've actually got access to a concrete saw if cutting it into sections is beneficial. Casting in sections doesn't seem out of my scope of abilities either though likely far more involved. I'm looking forward to getting underway. Been lurking quite a while and just bought a new home that is begging for backyard improvements..
