Insulating base board in the UK - Forno Bravo Forum: The Wood-Fired Oven Community
  • Insulating base board in the UK
    I am looking at the following web site to obtain the insulating base board. Ideally i do not want to have to build a 4 - 6 inch thick perlite or vermiculite insulating layer, and would prefer to use one of the specialist insulating boards plus maybe a couple of inches of the vermiculite or perlite mix.
    The question is which board should I use and is the board considered to be superior to the diy V or P mixes?
    Superisol 30 ?
    Promasil 30,40 or 50 ?
    Silica boards ?
    Building materials-Insulating boards-Superisol-isolation slab Superisol 30: Stoves, ovens, fireplaces, heating and bathrooms - PROFISTAVBA.EU
    Brad
    Re: Insulating base board in the UK
    I think the superisol 50 will give you the two inches of insulation you need.
    Building materials-Insulating boards-Superisol-isolation slab Superisol 50: Stoves, ovens, fireplaces, heating and bathrooms - PROFISTAVBA.EU
      wow that was quick.
      would I need anything else under the Supersol? or would the 2 inches be enough?
      Brad
        Yes, I have 2 1/2" of a less good (mineral fiber) board, and my support slab hardly gets warm to the touch. That should be good.
