Best insulator for the dome - Forno Bravo Forum: The Wood-Fired Oven Community
  • Best insulator for the dome
    I am about to insulate my dome with 4+ inches of ceramic blanket and a top coat of 1 inch or so of perlite mix. I also have about 1.5 squate meters of 1 inch ceramic board left over from the base insulation and wondered if I could incorporate this into the insulation at the top of the dome.
    I wondered if there would be a benefit in using this spare insulation, and if i should place it before the ceramic blanket ect. ect. ect.
    I thought that the ceramic board was a better insulator than the blanket, but I am not sure if it would be a good idea to incorporate it into the dome insulation.
    Brad
    Re: Best insulator for the dome
    Brad,
    You might want to hang on to the board. You can make a nice insulated door out of it.
    4+ inches of blanket & a few inches of perlite will do great.
    Ken H. - Kentucky
    42" Pompeii
      Agreed. The board is typically used under the cooking floor, and really won't add anything to the dome.
      4" of good quality ceramic blanket (plus a little perlite or vermiculite to fill any corners -- if you have it) will do a great job.
