using FB boards - Forno Bravo Forum: The Wood-Fired Oven Community
using FB boards
  • using FB boards
    I am building a 42 inch pompeii. The sales dept at FB told me to purchase 3 FB boards for this sized oven. I cannot figure out how to orient them to make the oven fit. Anyone care to send me a sketch?
    Mike - Saginaw, MI
    Picasa Web Album
    My oven build thread
    Re: using FB boards
    Put two side by side to make it 36 x 48. Put the third one down rotated 90 degrees. You may have to do some trimming to get the pieces you need to allow all the dome bricks to sit on the board. My board was a different size then the FB.
    Les...
      Re: using FB boards
      Mfiore.
      Exactly as Les says. I startedmy oven at the front of the boards so I would have a nice clearn edge.
      I think you'll be happy that you got the boards - I know I was.
      Dick
      Thte boards is easy to cut - be sure to wear a mask.
        Re: using FB boards
        OK, now I'm still feeling a little dumb. Still can't make it work. A 42 inch oven with 4.5 inch walls is 51 inches across. I need to cut a three inch piece off the third to cover this. No matter how I arrange that third piece, it doesn't seem to make up for the difference. I think I need a fourth board.
        Dick,
        I re-looked at your thread. Your oven wasn't 42 inches, was it?
        Mike - Saginaw, MI
        Picasa Web Album
          Re: using FB boards
          Hi Mike,
          If you do need the fourth board, email me, and we will send it to you without a freight charge. I will also take a closer look at our "recommended FB board" web page, and make sure we are recommending the right number.
          Sorry about the hassle.
            Re: using FB boards
            Mike
            Duh, you're right mine was a 36... sorry about that. For some reason I thought i had to trim off more than I did...
            Dick
              Re: using FB boards
              Or... you might use something else of equal thickness under the walls and use the board you have for just under the floor - where you need it.
              dusty
                Re: using FB boards
                Here's how to make it work: arrange your three boards into a "T". you are going to nip off the corners of the upper tee to fill in the places where your oven overhangs. Measure in diagonally 5 3/8, and 9 3/8 from each upper corner, and draw and cut 45 degree lines at those points. The four offcuts will fill in the corners where your circle overhangs. PDF of drawing enclosed:
                  Re: using FB boards
                  I spoke with the folks at FB again, they think 4 boards is more appropriate for a 42 inch oven. I ordered one before seeing dmun's sketch.
                  dmun, thanks for the sketch. Your drawing sure beats me cutting pieces of graph paper! That looks like it would work, with quite a bit of cutting. Still, would save $70! (although I'm not confident I would have cut mine so precisely. Probably still would have splurged for the 4th board)
                  Perhaps James should send a sketch like that out with the boards he sells. thanks again, dmun. Hopefully it will help future builders.
                  Mike - Saginaw, MI
                  Picasa Web Album
