2-chamber oven floor material - Forno Bravo Forum: The Wood-Fired Oven Community
  • 2-chamber oven floor material
    Ok, so I've built an oven with a fire brick floor made of cob and I'm starting my second oven. I want to build a 2-chamber oven (fire underneath, cooking chamber on top) and I'm looking for a material to use for the oven floor.
    Is there any kind of stone that could be used as the floor of the oven to separate the two chambers?
    I would like it to be something large and extend outside the oven perimeter so there would be a little shelf for setting things.
    Any ideas? Is this possible? Do I need more support than just a slab? Help!
    Re: 2-chamber oven floor material
    Leah, You might consider a slab of soapstone but depending upon your location the savings from building in cob might be considerably offset by it's cost. You might also consider a large piece of plate steel or cast iron and support it by embeded stones so it's free to expand and contract. I picked up a large cast iron griddle out of a commercial range at the county dump. I use it over a large split rim wheel for campfire type cooking. But with scrap metal prices being what they are this sort of stuff is rarely available free anymore.
    I have two neighbors who have ovens of cob. Both are uninsulated and both vent thru the entrance like a traditional Canadian clay oven. One of the two is really into cob, been to workshops and now conducts his own. He's built a small building as well.
      Wow, thank you, great ideas!
      A cob building is in my future but ovens are so much easier to finish!!
      I agree that it would be crazy to build the entire oven for free then spend $1,000 on a piece of soapstone (though I have no idea how much it would actually cost). I'm going to go see what I can find at the scrapyard.
        Check out the following post that was lively some time ago...there are some options discussed and a link to a builder of what might be a similar design
