new oven build
  • #16
    Re: new oven build
    What if you double up on th floor with fire brick
    • #17
      Re: new oven build
      Sumu,
      That won't change what's underneath it all. The firebrick and insulating level serve two purposes. The firebrick is a thermal mass to store heat. A thicker floor just means a longer time to heat up. The insulation will keep it from being lost below, resulting in a cold floor. Stick with the recommended insulation of either vermiculite/concrete or an insulating board designed for refractory applications.
      Mike - Saginaw, MI
      Picasa Web Album
      My oven build thread
      • #18
        Re: new oven build
        Originally posted by dmun View Post
        No on both counts. The pink foam insulation board is not rated for hot environments, and will give off weird smells if it gets even a little bit hot.
        It's probably worth pointing out that those weird smells also tend to be fairly toxic.
        • #19
          Re: new oven build
          i talked to a sales rep from a furnace place he said he had 1 inch mineral baord that i could double up on and it would be fine cost is 3.00 a square. 30.00 for 36" diameter. what do you think....
          • #20
            Re: new oven build
            Sumu,
            I would get a hold of the specs and compare them to some from the forum that are known to work well. If you can get the name of the board he is referring to, you might track down someone who has had experience with that board. Some of them insulate well, but get really mushy if they inadvertently get damp.
            Mike - Saginaw, MI
            Picasa Web Album
            • #21
              Re: new oven build
              Agree ^^^^ 2" of cal. sil. is the best option.
