Vermiculite vs. Perlite vs. blend - Forno Bravo Forum: The Wood-Fired Oven Community
  • Vermiculite vs. Perlite vs. blend
    Is there any difference between vermiculite and perlite?
    I have seen several ovens with a vermicrete hearth insulation layer but perlite+concrete dome insulation. Is this for a reason?
    Some ovens even use a blend (mostly 2:1) of vermiculite : perlite in their insulation layers.
    I'm confused! All information / recommendations appreciate for an ingloo-style pompei brick oven.
    Re: Vermiculite vs. Perlite vs. blend
    They both work fine. They are different colors and textures (vermiculite is brown cubes, perlite is white spheres) I used the perlite, and it's a little easier to see when it's fully mixed in, because the white turns grey, but it's mostly a factor of what's available and affordable.
      I used it under my hearth just fine 5.5 inches and over the dome as well. By blending the portland in the water I was able to mix in a lot of perlite.
        Perlite is a slightly better insulator than vermiculite, but is also slightly more expensive (at least it is where I live) I prefer the vermiculite to work with because perlite seems to have some really fine particles that are irritating if you breathe them, the vermiculite doesn't seem to have this problem. I guess these materials vary a bit from place to place.
          I used perlite (couldn't find vermiculite).
          I believe I used 5 parts perlite to 1 part portland. Tip - mix the portland and perlite (or vermiculite) first THEN add the water.
          My 2 cents.
          Dick
            Bit of a noob question probably, but searching hasn't revealed the answer.
            When measuring the ratios, is it by volume?
            ie, 5 buckets of Verm + 1 bucket of Cement, and add water?
            This seems like a lot of cement, as 1 bucket will be ~25kg or an entire bag of cement?
            I'm nearly finished my dome, and will be thinking about the outer insulation soon.
              By volume
              Les...
                I completely agree.
                Stick with Verm if there is a choice.
                Perlite also flies into the eyes.
                My thread:
                My costs:
                My pics:
