did i use the wrong mix
  • mini
    Re: did i use the wrong mix
    Whew -
    Thanks alot...
    Mini
  • dmun
    Insulate! Insulate! Insulate!
  • mfiore
    Don't put the firebrick directly on regular concrete. You need some form of insulation, or you will lose all of your heat, resulting in a cold floor.
  • james
    Hi Mini,
    Welcome aboard! I moved this to Getting Started. You should get more help here.
    The hearth under the wood oven has two layers. A concrete slab, that holds everything up, and on top of that, a layer of either vermiculite or FB Board insulation. The oven floor rests on top of that.
    If you follow the plans, I think you should be OK.
  • mini
    started a topic did i use the wrong mix
    First, thanks for this forum -
    I downloaded the Pompeii instructions several months ago and started construction on a 1200 sqft fieldstone patio with oven last week.
    I poured the base last week for the Stone House oven and now realize that I may have used the wrong mix. I didn't use vermiculite - just regular concrete - is this a total screw up?? I plan on using the fireplace a lot - will it be okay to just use the firebricks on top of the reg. concrete??
