New Under Oven Insulation Board
Yeah mate, i'll definitely let you know how she goes. We were lucky enough to meet someone at an insulation company here who donated a heap of board and glue to us for free. We're making a documentary, so sticking a camera in someone's face doesn't hurt. Are there any junkyards nearby you could hunt through to find similar ovens with similar insulation in? Maybe one inch thickness is enough. I'm certainly counting on it.
thanks, mate!
Hello Redbricknick, thanks for the update - pls keep me posted opn your experience (it will be a while before I get to that point in the construction...)
My two 1in sheets cost me $A84, BTW! But I may be able to prise off a thin sheet of similar looking material from under the oven cavity of an expensive old electric oven that I'be now junked after 13 years of mostly repairs :-)
Cheers,
Carioca
Cal sil.
My calclium silicate insulation board is one and a half inches. The dude who donated it to us said it was rated to twelve hundred degrees. We'll see, but I'm pretty confident it will insulate sufficiently.
CalSil thickness ?
Hello James,
on the order sheet I just received from my supplier in Melbourne, Australia, there are two sheets of calcium silicate board listed for under the cooking tiles (2 in) of the 1000 mm (ID) dome - but these are only 25 mm thick (1 in)! Is that sufficient, or will I still need to pour a vermiculite/ciment fondu insulation layer under the hearth?
Thanks again for your help!
Rgds,
Carioca
Looking for an update on the Super ISO board
Has anyone got an update on the ISO board?
How is it working? Any lessons learned?
I plan on using this product.
Was not sure from the previous posts how hard the material is - Can you poke a hole in it with your finger? I bet not, but was concerned.
Christo
Exactly!
You attach the SuperIsol directly to the concrete layer, and you do not need the vermiculite layer. They serve the same purpose, so you don't need the vermiculite layer. That would be overkill, and you don't need to go to the expense of hassle.
We sell a high temp caulk to ahere the panels, which I will put into the Forno Bravo Store latery today. It isn't expensive, so you don't have to waste time looking for a safe product to use.
Cool stuff.
James,
Just to be clear. If I use the new insulation board do I not need the insualtion layer on top of the concrete hearth?
Thanks,
Ryan
Glue
Fud,
I'd go for Bulldog Premium construction adhesive. It gets stronger with heat. Not much of a chance the board would come down. Alternately, try to find Bond Lock. We use it for stone, and it's even stronger.
Jim
glue for insulating board
If I were to glue the new whizzy insulating board to the vermiculite layer under the hearth what type of glue would you suggest Would silicon work? Is it worth the trouble re heat retention in the hearth ?
Now I get it
je
Thanks for expanding the logic on this. I haven't had any doubts about the perlite or vermiculite concrete strength because of the information that's been presented so far. Now that you've done the math it is reassuring but more than that it's fun to see the math problem worked out. I just couldn't see where you were going at first.
Mike - definitely go for it. I am just nit picking and trying to keep my brain thinking. I probably should have made my post a private post to James. Doing a Google search I think that the units are wrong (ft^3 instead of in^2). that is also supported by quick experiment that James did.
If you search the threads you will find that the compressive strength of vermiculite has been discussed and approved.
http://www.fornobravo.com/forum/show...ssive+strength
Or you could read my ramblings below:
POOL COMPRESSION CALCULATION (Simplified)
1 gallon of water equals 8.33 lbs.
A 5 gallon pail has a diameter of 11.125" and a height of 13.25"
5 gallon pail/bucket contains .75 cubic ft.
take a column of water in a pool that has the dimensions of the 5 gallon bucket and a pool depth of 12 feet. What is the compressive equivalent pressure?
the pool is 12 feet high or 144 inches and the bucket is 13.25 inches : 144/13.25 = 10.9 buckets call it 11
there are 5 gallons/bucket and you have 11 buckets so you have a total of 55 gallons
there are 8.33 pounds/gallon of water and you have 55 gallons : 8.33 X 55 = 458 lbs round it up to 460 lbs.
that weight is on a diameter of 11.25 inches or on a surface area of 99.4 in^2 (Area = pi d^2 / 4)
so you have 458 lbs pushing down on 99 in^2 or 458/99 = 4.6 psi
vermiculite & cement = vermiculite concrete, at 6:1 mix has an average compressive strength of 155 psi
POMPEII COMRESSION STRENGTH
I am going to make some gross assumptions (lean toward conservatism) here.
Assume the weight of the oven is evenly spread about the circumference of your first ring.
Assume that each brick weighs 10 lbs (conservatism since they really are closer to 8).
Assume that the dome takes 200 bricks (a 42 inch dome is 180 bricks)
Assume you decide to use a fa?ade of bricks, say 350 and instead of bearing the weight on their own circle you manage to make the dome bear the weight.
Assume the width of the weight bearing brick is 3 inches and the inner diameter of the oven is 42 inches thus the outer diameter is 45 inches (that will give you the area that bears the load)
Assume the opening for the door is 15%
Area of a 45 inch circle is 1590 in2
Area of a 42 inch circle is 1385 in2
Subtract the inner circle from the outer to get the area of a Closed Oven is 205 in2.
Remove 15% for the door and your bearing area is 174 in2
that area is loaded up with 550 bricks at 10 pounds each or 5500 lbs
How much pressure is it made to bear? 5500/174 ~ 32 psi way below the compressive strength of 155psi
jeLast edited by jengineer; 07-07-2006, 10:50 AM.
Hi Mike,
Vermiculite has great compression strength and will easily hold up your oven, arch, etc. As someone once noted, vermiculite concrete is used under swimming pools, that are a lot heavier than your oven!
On the Super Isol compression numbers, I will have to check. It has lots of little air holes, but it has good compression strength -- I just tried to push my thumb into it, and cannot make an impression. I had to push hard with the cap of a pen to make an indentation.
Vermiculite Concrete
I have to say that I'm impressed after reading the attachment. I'm having trouble following this through to a conclusion. I'd like to know if this says that the compressive strength of this and perlite concrete really is sufficient to hold up a firebrick dome and floor. Also did this conclude that the vermiculite and perlite versions of concrete will provide the appropriate amount of insulation for this application. And of course, does the new insulation technique do as well.
I'm already poured in the hearth area and my floor is down, so I probably wouldn't make any changes unless someone says "Stop already!"
Thanks for the great research.
Thermal Conductivity
I have been corresponding with a builder regarding strength of vermiculite cement mix, volumes of 5 gallon buckets and how to get a 6:1 mix. The supplier of the Vermiculite provided a nice handy chart that showed the material strength, density and the thermal conductivity (k). k, is the physical property of a material that indicates its ability to conduct heat. The smaller the k the better it will insulate. According to http://www.schundler.com/vermcon.htm, a 6:1 ratio ranges from 0.69 to 0.73 and an average compressive strength of 155 psi, cork, fiberglass, mineral wool on the other hand can be as low as 0.04., however cork will squish like no tomorrow.
Thermal conductivity of this product is a bit better, plus the numbers show the conductivity at higher than standard day temperatures which is till good.
Are the units in the Compressive Strength correct? PSI maybe? The spec say 377 lbs/cu ft which doesn't make engineering sense in terms of units. If it was meant to be lbs/sq ft then that is equal to 2.6 psi - that means you can poke a hole in it with your index finger. A brick spreads the surface area out and may not crush it, more on the lines of 0.22 psi.
Note in the spec:
Modulus of Rupture: This measurement shows the maximum bending load that a beam can support. The number indicates the stress required to cause failure. The higher number means that a greater force is required to cause failure.
Compression Strength: Compressive strength is the capacity of a material to withstand axially directed pushing forces. In this case think of loading up the item against a surface where it can?t bend. Easy way to look at this is in terms of jack hammering. If the hammer isn?t hit onto the concrete walk way hard enough nothing will happen. Hit it really hard then the head of the hammer will crush/pulverize the concrete. Now if you loaded up the concrete to the same load that was applied by the hammer then a static load would also crush the concrete. See any California Highway for a correlation. Now if you had foam then of course it will compress thus the terminology, compressive strength.Last edited by jengineer; 07-06-2006, 02:58 PM.
Hey Caveman,
Always the best questions. I made a spec sheeet, and posted it here:
http://fornobravo.com/installation-e...superisol.html
It's made in Europe and imported by a furnace supply company. We are now stocking it in California. The two main components are 45% Silica and 45% Calcium Oxide. We are doing the first installations under ovens now, so there is more to come on that. It will stand up to the sands of time, and has a good track record in more demanding industrial applications.
Like any insulator, it doesn't want to get wet, and needs to be set inside your waterproof enclosure. I don't know if the insulation would break down, but it would take heat out of the oven to drive out the moisture. But then any water that made it to the floor insulation would probably have already done damage to your woven ceramic insulation around the dome.
A funny aside. One of our competitors (that I like poking fun at) still recomends that you use 6" of SAND in the hearth -- between two layers of concrete. Talk about a sponge attracted to water. I have been to one party and talked with someone who attended a different party/different oven, where the hearth sand had absorbed water from winter rains, and the oven just would not heat up. It was stuck at 350F after hours of firing. We had take out pizza, and later heard that the oven took over a week of fires to dry out.
Finally, I don't think this is something you can find in somebody's back yard. Oh well. I have heard that crushed glass and ashes from wood fires are good old-fahsioned insulators. If you live near a volcano, tufa works well.
