oven stand - Forno Bravo Forum: The Wood-Fired Oven Community
oven stand
  • oven stand
    Is it possible to build a 36" pompeii oven on a steel frame so i can move it from my garage to outdoors.
    thanks for response
    Re: oven stand
    Yes. FB actually sells such a stand although it isn't mobile.
    [/CENTER]
      Re: oven stand
      mar 1812
      Anything is possible. All you need to do is to calculate the all up weight and have a reinforced steel 'chassis' or stand made preferably with 6 castors if you want to continually move it easily.
      A metal fabricator will meake easy work of such an exercise.
      Neillís Pompeiii #1
      Neillís kitchen underway
        Re: oven stand
        Thanks neill
        what do you think a 36" oven would weight
          Re: oven stand
          Are you talking a brick or a FB cast refractory oven?
          I built a 40" Pompeii and used around 130 full firebricks and 30 odd house bricks, multiply them bu 3-4kg each Plus the insulation (either board which I would suggest to keep the weight down) and the dome insulation (again I suggest the superwool thermal blanket).
          This would total to about 700kg or around 1600 lbs.
          If you use a cast FB oven, you will need to contact them for their weight but I would expect them to be at least half as they are much thinner but designed to do quite specific tasks. If you want to cook longer, then you must add extra weigh in thermal mass.
          Neillís Pompeiii #1
            Re: oven stand
            Hello mar 1812
            Did you see the recent photo posted by Resalto. Jones? if not here is the link
            PhotoPlog - Finished Ovens
            Could you not try for a sclaled down version of his commercial wood-oven? Hope this is of some help to you.
            Terry (C.F)
            Honi soit qui mal y pense
            My 2nd Pompeii build.....
            http://www.fornobravo.com/forum/memb...eii-build.html
