inner arch to dome? - Forno Bravo Forum: The Wood-Fired Oven Community
inner arch to dome?
  • inner arch to dome?
    Hi All, Thanks again for all the info. I have a question regarding the joint between the dome and the arch. I had a thought of maybe cutting the connecting bricks very tight and not mortaring them to the inner arch, I would fill any gap with insulation. My thinking is a slip or exspansion type joint might relieve some cracking on the archwork. Do you think there would be some reason not to pursue this? Any and all thoughts are appreciated!
    John
    Re: inner arch to dome?
    stonejohn
    While your waiting for an answer, here's a link which will take you straight to a thread, where the exact same topic is covered.
    http://www.fornobravo.com/forum/21/3...e-7878-23.html
    Terry (C.F)
    Honi soit qui mal y pense
    My 2nd Pompeii build.....
    http://www.fornobravo.com/forum/memb...eii-build.html
      Wow, I've checked out your website and I can't believe you've had the time to do both, your attention to detail, except maybe for the concrete, is second to none! Well done.
      I can only hope mine is as good when I'm finished.
      Les
        Who was that directed at? If me, then thank you very much.
