expansion joint? - Forno Bravo Forum: The Wood-Fired Oven Community
expansion joint?
  • expansion joint?
    Hello
    I've seen some examples (can't remember where!) of a gap between the inner dome and the cosmetic brick work. It sounds logical to have one I suppose.
    Has anyone used one? what did you plug the gap with?
    Any hints-tips will be appreciated
    Mick
    Re: expansion joint?
    I think I understand your question.
    Insulation goes on the outside of your oven bricks, then the cosmetic brick work. Lots of insulation. Then you can have a gap or not. I don't think it matters. The builders who used stucco to finish the top of the oven used no gap.
    Hope this helps.
    dusty
      Thanks for the reply ... maybe I should have explained my query better
      I mean where the hearth and the chimney work meets the outer/cosmetic brickwork
      Mick
        Mick,
        I didn't use one, but when you mortar the brick, you almost get one by default. The mortar isn't going to be solid between the two bricks. I did separate the brick from the flue about two inches and filled the gap with vermiculite/portland for insulation.
        Les...
          I just put a piece of foil to create a slip joint there. You could use the flat stove door gasket material if you wanted to get fancy. There's also a quarter inch version of the insulating blanket, but I'm sure you'd have to buy the whole roll.
