Fitting arch to dome - Forno Bravo Forum: The Wood-Fired Oven Community
  • Fitting arch to dome
    We've put our Ristorante 130 together and are about to apply the mortar to the joints.
    The arch fits in a way that there is a large gap between the oven floor and the landing.
    Which is better:
    Fill the large gap with mortar?
    or
    Grind down the back of the arch to get a better fit?
    Re: Fitting arch to dome
    Perhaps the oven was designed this way by the manufacturer. I've done a similar thing with mine to isolate the arch from the inner parts of the oven to reduce heat conduction to the uninsulated arch. I use vermicrete. You should ask the manufacturer of the oven.
      Thanks, David-
      your explanation does make sense. I talked to somebody over at Forno Bravo. I'm going to send him pictures of the oven.
      --Steven
        PLEASE SEND pictures
