fixing a warped floor after install is complete - Forno Bravo Forum: The Wood-Fired Oven Community
  • fixing a warped floor after install is complete
    My Casa2G came with a slightly warped floor piece that presented a small lip on the left side. The corners of the pieces meet, but the mid section does not line up.
    When I called Forno bravo about this, they said that this generally doesn't pose a problem, I asked about grinding it down, and they said don't that the floor surface was different than the inner block and that would be a bad idea.
    I just got my peel, and while doing a curing fire, played with it a bit. It in fact seems to catch pretty bad. I feel like using a dremel to bevel the back tile would help immensely - does anyone have any advice on this?
    [sorry - photo is posting upside down, but side closer to fire has lip]
    -Preston
    Re: fixing a warped floor after install is complete
    Hey ptone
    I actually received two warped floor pieces. Luckily I spotted the problem before assembly and FB is replacing them. Seems that I read here that you can remove the pieces once assembled. If you can do that I would ask FB for a replacement for the warped piece.
    Phil
      I'm going to see if I can remedy it first, FB contacted me off-forum. Their service so far has been top notch.
      -P
