Gaps between oven floor pieces - Forno Bravo Forum: The Wood-Fired Oven Community
  • Gaps between oven floor pieces
    On the newly built oven floor of my Casa 2G I noticed there are a couple of very small gaps between some of the floor pieces. These gaps are probably between an 8th and a 16th of an inch wide. Does this present a problem?
    Re: Gaps between oven floor pieces
    No - they will fill up with ash and burnt pizza. As long as the peel will slide over them, you are good to go.
      Confirmed- no problems. I'm guessing you might be an engineer.
      My oven (for now):
      http://www.fornobravo.com/forum/f43/...ven-14269.html
