Uses for fire brick dust - Forno Bravo Forum: The Wood-Fired Oven Community
  • Uses for fire brick dust
    Hi All,
    Any ideas for using fire brick dust left over from fire brick cutting?
    I've been cutting bricks as needed and have developed quite a pile of residual dust from the tile saw.
    Can I use it to fill small gaps in my oven floor between bricks? Are there other, better uses? Should it be applied dry or wet?
    Thanks!
    Re: Uses for fire brick dust
    You can use it as a fine aggregate for your mortar.
