Premio100 single wall chimney into double wall? - Forno Bravo Forum: The Wood-Fired Oven Community
  • Premio100 single wall chimney into double wall?
    Hi Guys,
    have a question regarding chimney installation. i have a single wall chimney that came with the premio2G100 and in the process of building the enclosure for it.
    would it be ok to use the single wall chimney and attach an adapter to it that would convert it to double wall then through the roof?
    Enclosure built with steel studs and HB.
    any thoughts?
    thanks
    Peter
    Re: Premio100 single wall chimney into double wall?
    That should be ok as long as you use the right adapter and maintain the proper clearances. FB support may have what you need, try them. Sorry for delayed response.
    Texman
    Texman Kitchen
