silver foil - insulation layer - Forno Bravo Forum: The Wood-Fired Oven Community
  • silver foil - insulation layer
    hi all
    About to start the insulation on my dome....after a few running repairs this morning
    Is it best to put silver foil on before the blanket and then the vermiculite outer layer
    or
    blanket - silver foil - vermiculite..
    or
    silver foil - blanket - silver foil - vermiculite...
    also the vermiculite outer mix is 5 -1 cement is it ok to add a little sand to the mix
    cheers
    Re: silver foil - insulation layer
    With silver this morning at $13.75 an ounce, I'd skip the silver foil. In fact, I'd skip any foil whatever. The most common, aluminum, will be corroded instantly by the portland cement. It really doesn't have any function.
      Originally posted by ross View Post
      hi all
      cheers
      Hey Ross,
      The foil really doesn't add any value to the system with the blanket insulation. And the Portland does corrode the foil in short order.
      And the sand in the vermiculite mix will not add any value.. the idea is to get as much 'insulation' as possible, and that comes from the vermiculite. You use the Portland (cement) to hold the vermiculite together. The less Portland you use the better the insulation value; there is one guy in this forum who was getting as much as a 12:1 mix. As some point you need the Portland to provide the strength to keep the whole thing together and you can't go wrong with the 5:1 mix.
      JED
        Don't add sand the the vermiculite cement mix. The idea is to just coat the vermiculite with cement as loose as you can. The mix creates tiny pockets of air- those pockets insulate (think of a double pane window, thin layer of air in between the glass). If you add sand you fill in the air pockets and lose insulation.
        See ALL of my pictures here:
