casting dome ???? - Forno Bravo Forum: The Wood-Fired Oven Community
casting dome ????
  • casting dome ????
    I would like to know if I dont want to use firebricks at all in the oven dome can I cast it in one piece and what material should I use for casting so it can retain heat and reach up to the right heating temperature without cracking using a gas burner ?
    Re: casting dome ????
    hello!
    do a forum search for "casting dome" you will find a ton of info. good luck to you, and please keep us posted on your build with pictures
      Gas burners aren't recommended for home ovens: the gas can accumulate in the closed dome, with a risk of explosion. Commercial gas burners are used in a commercial environment, and have many safety controls.
