BBQ pit plans, designs, racks - HELP!! - Forno Bravo Forum: The Wood-Fired Oven Community
  • BBQ pit plans, designs, racks - HELP!!
    So after some talking back and forth with a buddy, I decide to build a Wood Fired Oven (42" diam.)and face it with brick and rock. Then like everything else I do, the project starts growing before I even start.
    So far, I have drawn plans for the 42" diam. WFO, Concrete counter next to it, the new big ol patio slab, a small 24" high retaining/sitting wall and now I want to add a old style brick firepit/bbq.
    This brick bbq pit will have a inside opening dimension that is about 48" long and 20" wide. I plan on having the back side higher with the counter top running on top that can house friends sitting on the back on bar stools (my friends do this well).
    I plan on using it for both a fire pit (normal use) and as a bbq pit for parties since my wife made me buy a goofy "Vidalia" BBQ insert that actually only has flame on one side.
    I plan on making the cooking surface from a stainless steel heavy wire mesh supported in a angle iron frame. I also want the cooking surface to be height adjustable with some kind of crank. And of course I already have found a 110 volt gear reduction motor (6 rev/min) to turn the spit for a pig, lamb or multiple birds.
    Anyway, I have had such GREAT help on this forum regarding the design of the WFO and I have NOT been able to find much info on building a brick bbq.
    Does anybody know of any good sites, so that I might learn form others?
    Thanks, Eric
    Thanks, Eric
    My 42" dome build pics in Napa
    My build thread part I
    My build thread part II
    Re: BBQ pit plans, designs, racks - HELP!!
    "stainless steel heavy wire mesh supported in a angle iron frame."
    Cast iron grills might be your best bet. Sometime you can score a set for free at your local landfill from discarded gas barbecues.
      Stainless steel works great indoors, but it is not really stain less outdoors, especially in a small diameter mesh. No matter how you end up building it you should line it with firebrick and add a chimney.
      I can not imagine using the backside of a BBQ pit as a seating area, too much smoke and heat.
        ...but it is not really stain less outdoors, especially in a small diameter mesh.
        I am not going to be using "small diameter mesh", it is a large gauge and wide spaced stainless mesh. I have been using stainless outside for years.
        ...I can not imagine using the backside of a BBQ pit as a seating area, too much smoke and heat.
        It is going to be a multi-function pit. It will have a removable, height adjustable gril/cooking surface for Q'ing during parties, which will be removed during the family and (close) friends evenings, there will also be a heavy metal cover to close off the pit if so desired.
        And what I was asking was "Does anybody know of any good sites, so that I might learn form others?"
        I am looking for some ideas for the cooking surface height adjuster, pit drain holes etc,
        I just figured that someone might know of a good website/forums that has the same level of knowledge on brick bbq's that the FB has on WFOs.
        Thanks, Eric.
        Thanks, Eric
          Eric,
          Try this site:
          BBQ Source Forums -> Custom Built Grills & Smokers
          Good luck.
          John
            I have looked on this site and they helped me a lot with the many "variations" of wire mesh that might be used or needed....
            Belleville Wire Cloth Co., Inc - Woven Wire Mesh | Wire Cloth | Stainless Steel Wire Mesh | Wire Cloth Strainer
            Stainless Steel mesh looks like it will be absolutely my best bet if I am going for an indoor cooking venue, but I question the size of the mesh that I need.
            How big is the openings that you guys usually see between your wire mesh?
            Would you say it is like a 2 x 2 wire cloth or more like a 40 x 40 count? Very fine, or just fine enough so nothing falls through. Thanks for any tips on this guys, think I have the right alloy in mind, just debating the size.
            _J_
              I am not so sure that stainless is what you want for your grill. Cast iron seems to be the most popular.
                Why not stainless? The heat factor?
                I am going to call belleville wire cloth, the guys who sell it and ask them.
