Another one of my wild thoughts.... - Forno Bravo Forum: The Wood-Fired Oven Community
  • Another one of my wild thoughts....
    What about an upturned cast iron bath for the oven, then cover with mass of some sort like gravel, broken bricks, then insulation?
    Just cut the bath off to length then build the front arch etc as normal.
    The baths are available from Epay for about $200.
    You could even get a white one so the dome is always white...
    The enamel according to wikiP doesnt melt until between 750 and 850 ?C
    Re: Another one of my wild thoughts....
    The enamel won't melt but it will probably crack and fall off but... you can also get scarey close to the temps you quote in the dome!
    It would work better for pizza than bread because pizza doesn't particularly depend on retained heat other than the hearth. While one could certainly bake bread in it, the loose gravel/whatever would not be likely to store or conduct heat nearly as efficiently as solid refractory (but coating it with refractory won't work for the thermal expansion will break the refractory up.
    Try it and report back!
    Jay
      I'd be a little concerned about the lead content of old enamel.
        Just one question.....
        What are you smoking/eating to conjure these ideas?
        Never hurts to think outside the box. If you want a readymade oven, the end of a large propane tank sounds good. Somebody posted about it recently.
        Stay dry Brickie, and trim the vegetation around your house to retard the next roaming fire
        I buried one of those tubs in my yard, you can have it for free, just stop buy and I'll help you dig it up. It was slightly used however
        My best to you.
        Lee B.
        DFW area, Texas, USA
          Ive always had "these" thoughts, and think it strange that others dont....
          Never hurts to put it out there.
            Jay
            It may be a while....
              Aw, Brickie! You're just trying to lure some unsuspecting lout into building your "nightmare" and saving you the time and trouble! )
              More seriously, I think it would/could work pretty well for pizza though dmun's comment on lead is well conceived.
              Things do get twisted around down in Australia don't they!
              Jay
                Around here they end up half buried as someone's front yard grotto with the Virgin Mary standing inside.
                (No disrespect intended)
                  This has been proposed before:
                  http://www.fornobravo.com/forum/f3/c...oven-8640.html
                  As for "flaking off" of the enamel I suspect not, rather more likely to bubble and get ugly looking. As for expansion cracking an externally added thermal mass: this shouldn't be a problem if one accounts for it in the construction. My WFO has a steel interior and I made provisions for expansion and contraction and have had no problems with this.
                  The "Tuscan Grills" are cast iron as are alot of the gratings in furnaces and grills in quality BBQs. Cast iron is actually quite stable in the temps we are normally working.
                  Bests,
                  Wiley
                    So Im not the only fruit loop?
                      Maybe just a Frosted "Flake"
                      RT
                        Hey....if you have a bathtub, make an oven, and if the enamel flakes, and cracks, just burn it off with high firings. Bare cast iron would be ok.
                        Old ovens were made of anything available. Add some scrap steei to Tman1's oven, insulate, and go. Take Dmuns geodesic shapes and cast them in iron....with a system to clip them together...and go.....this is like Mechanics Illustrated magazines just after WW2!
                          You are welcome to it
                          Lee B.
