linning a webber with refractory material - Forno Bravo Forum: The Wood-Fired Oven Community
  • linning a webber with refractory material
    can anyone help with a formulation of perlite and some type of cement i can line my webber grill with? i want a one inch thick material that can hold some heat and be on the light side. i have built my first oven and it works well. i need a better material mix.this was a product called solid flue that is not available to me any longer
    Re: linning a webber with refractory material
    If you use perlite in the mix then you reduce the amount of thermal mass. You also make the casting weaker. You really need to insulate the outside as well. It might work, I have successfully made a castable using 50/50 castable refractory and perlite reinforced with stainless steel needles. If you want to go a cheaper route then try the homebrew mortar recipe instead of a proprietary castable, but add some animal or human hair (which burns away) to it to create pipes that allow moisture to be removed better.
      this is all new to me. please explain the home brew recipe. i am trying to keep the weight down.this unit has 3/4 inch of solid flue with wire last holding it to the grill cover.i can insulate and cover the outside.
        The homebrew recipe is 3:1:1:1 sand, fireclay,lime,cement.
        By adding perlite to the mix you make it more insulating so it will take longer for the heat to soak through it. You might be better off making it denser but thinner to save weight. Experiment and report back, this is good.
          If you think an oven dome with no thermal mass is gonna work for you, why not just form an oven cavity out of stainless steel sheet metal. That really opens up your options for insulation. Anything from loose fill inside an enclosure to a perlcrete with very low portland content covered in some sort of render to hold it all together. I think you'll get a much better result then trying to formulate a home made insulating castable refractory that is structurally sound through many heating and cooling cycles.
            have any members herd of a product called solid flue?i is sed to line damaged chimneys. my friend claims it is very efficient in holding heat as well as strong.
              Yes, and it would enable you to lift the lid with one rather than two hands.
                As for the solid flue, the product you are referencing seems to be an insulating castable refractory that is part of a proprietary system for relining chimney's in one piece. I was able to find their specs here:
                Specification Data Sheet
                Comparing them with the specs for Kastolite 26(found at the next link) the solid flue does have a much lower density and thermal conductivity. It is on the other hand considerably weaker them the Kastolite and the manufacturer says it is not structural. Your not looking to support a house of chimney with this stuff, just it's own weight so I would go with your gut based on your past experiences with it.
                http://www.BudgetCastingSupply.com/l...Literature.pdf
                If you don't mind me asking, what does this stuff run? I ask because insulating castables are notorious for being expensive, with the kastolite going for about $100 per 55# bag.
                  solid flue cannot be purchased by anyone but a authorized dealer. i had a bag that someone gave me. I'm cost wise its in the 100.00 range. the other material if it is available to the buying public might be useful.
                    Kastolite 26 is just one of many commercial insulating castable refractories. I mentioned it because it is one of the more common one that seems to pop up. If you want to go that route Harbison Walker has two locations in Ohio, and could probably point you to the best product for your purpose.
                      DAVID, you are far better using shredded plastic or chopped up rope. Some refractory castables have polypropalene fibres added for RFT. [Rapid Fire Technology] Human or animal hair would stink.
                        True, but at least it won't be toxic. I don't like burning plastics.Natural fibres for me.
                          how would i form a mold if i want to make a one piece dome using solid flue say 1.5 inches thick. we cooked 25 pizzas in this little oven last night. it maintained a floor temperature of 800 degree, and cooked Neapolitan 60 second pizzas for three hours straight.
                            You can form a mould from damp sand then cast over it. Remove the sand when it has set .
                            What d I'd you end up using for your mix? Did you also insulate it? Please share we're all interested.
                              i an using the solid flue. the mason that i know is the distributor and can use it anyway he wants.we took the oven to a party friday and cooked 25 pizzas with only adding one log every third pie. this was just a quick throw together project that cooks as good as my primevera 70 which i love very much.the solid flue is a very thin product a two sided mold would work best.i think i would be expensive to have made.Click image for larger version
