Originally posted by david s
View Post
As always I appreciate the input ( after all, you gave me the ideal of adding stainless steel needles ( To which I have purchased) to the mix.
As for using the experimental for mini pizza's and such: Unfortunately, I have given it to my beauty as a gift to compensate for Valentines day. It has been deemed "cute", so it will be finished with a chimney and destined for ???.
As for the dimensions of the barrel oven. It will be 36" x 48". My plan is to make it into 5 pieces (L/R Walls, Back and Front, Split arch in two)
The hearth firebricks will be within the walls of the oven. The walls are to be 9.5", but I will add 2.5" to compensate for the thickness of the firebricks. The opening will be 20"W, 12"H, arch should be about 19"H.
Any suggestions will be appreciated.
Thank you,
Sandro
