2 meter diameter New build oven with pumice reinforced with Basalt Rebar
The planning/Greenbelt restrictions prevents me from building a gazebo. A seating area is designed to benefit from the smoke emitted by the cooking surface of the stove and utilise the smoke/heat generated to run it under the granite slabs to heat it up theon. No calculations were carried out on how much heat is required, hence the two stoves are connected to the shaft created in between the two walls (with tiled surfaces). Someone's bottom is either going to be too cold or it will be burnt like hell by the granite surface!
An antique kakelugn ceramic stove from 1832, looks slightly like a Birthday icing is to obscure the stove. The antique kakelugn ceramic stove is yet to be assembled.Last edited by Alomran; 10-07-2021, 04:02 AM.
- 1 like
I love how you're repurposing stuff Alomran ! Your "Roman" heating solution is brilliant!My 42" build: https://community.fornobravo.com/for...ld-new-zealand
- 1 like
Ah well, you know the saying: Happy wife, happy life! LOL
I always remind my wife:
Remember, when a man says he'll do something, he will.
There's no need to remind him every six months.
- 1 like
