28" homebrew cast oven in walled enclosure Belgium
It is a trick to get the bottom crust right and the top right at the same time. I watch the bottom closely until it is just right, rotating with a banjo peel against the open flame then if the top needs some more work I do what is called "doming" raise the pizza on the peel towards the top of the dome where it is really hot, kind of like using a broiler. It will brown the cheese nicely and only takes very little time. I have both wood and aluminum loading peels and I find the the good old cheap wood ones don't stick like my expensive Italian steel peel.Last edited by UtahBeehiver; 07-19-2021, 07:08 AM.
Originally posted by fox View Post...having a queue of pizza waiting in line, then the sauce can soak into the base and that can make it stick to the peel.
If that happens then the pizza can go topsy-turvy into the oven or even.. completely up side down.. and then you have a very sticky floor that is not easy to clean up.
My tip when cooking for large numbers is …take your time and dont drink to much!
The main issue i have suffered comes from building the pizza to early or having a queue of pizza waiting in line, then the sauce can soak into the base and that can make it stick to the peel.
These sort of things can happen when you find yourself under stress and try to speed up the process so like i say… take it slow and keep calm.
Hi Johannes,
Thanks for you kind offer, I live near Mechelen so not really that close to Sint Truiden...
I would gladly give you some cooking tips, but I'm just as new to wood fired cooking than you are!
Do you have any pictures from your build?
one tiny thing I already learned is that it seems really important to always keep a fire with flames going as your pizza is in the oven. without flames it seems to take just a little longer, and the balance between 'fresh' topping (not dried out) and crusty and airy underside is difficult to achieve...
I plan to cook pizzais in the oven 3 times in august: once for 6 people, once for 8 people, and one real pizza party for 30+ people.
No doubt I will make a lot of mistakes along the way and learn from them as well.
I'll post my misadventures and successes here
hij Kris,
I see your in belgium , me to
i completed my build 2 weeks ago, and did the first real firing ( to pizza temp ) last weekend... also some minor cracks... but i don't think it should be a problem... i hope...
i see you wanted to make a fire dog? (log holder), i'm a hobby blacksmith/welder, so i'm gonna make me one from mild steel, i don't know where in belgium you are, but if you'r anywhere near sint-truiden, i't costs me about 5€ in steel ....so for some oven cooking tips i'l gladly make one... let me know
i was going to make em like this... but if anybody has a better design idea....
SS does have a tendency to warp but can certainly handle most oven temps, that said I never needed to use one. At one time I had a old fire place log holder to use in the oven but found I never needed to use it. Maybe others do.
- 1 like
Could I use stainles steel to make a DIY log holder?
I can't weld so can't make an iron one, but have some Stainles steel laying around that I could cut and bend to immitate the FB log holder…
Can it withstand the temperature?
Here's an expense overview for used materials: oven itself (+ stand) about €480. Enclosure an extra €260. Total about €742.
Only thing left to buy is the paint.
quantity total € remark hollow concrete blocks 39 * 19 * 14 cm 36 36 25 kg bags prepared concrete mix 45 135 25kg bags prepared mortar 2 5 rebar for ground slab, stand and hearth slab 0 free / salvaged wood for slab framework 27 fire bricks 32 64 25kg vermiculite + 25 kg perlite 35 +/- 2/3 used 25kg bags portland cement 2 7.5 25 kg bags sand for dome mould and homebrew 3 5 25 kg bag fireclay 1 17 +/- 10kg hydrated lime 0 free 1 bag 600g PP fibers 1 19 +/- 1/10 used ? 1 roll ceramic insulation blanket Insulfrax 25mm thick 96kg/m3 7320 x 610 mm 1 88 6" 90cm SS single wall chimney pipe 1 43 cement based boards 90 x 120 cm 12.5mm thick ( ~ hardiebacker) 5 125 wood for enclosure and roof 88 wire mesh for stucco 10m2 30 primer for stucco 9 more mortar for stucco? 50 kg 6 corner profile 1 3 alluminum panels for chimney 0 free / salvaged roof tiles 0 free / salvaged lead flashing around chimney 0 free / salvaged bricks for arches 0 free / salvaged OSB boards for various moulds 0 free / salvaged 742.5 stand + oven 481.5 enclosure 261
Thanks for your comprehensive report Kris. An hour and a half is usually about how long it takes for the oven to go completely white, but an extra 20 mins or so of "the fire from hell" is usually required to get it really charged. Usually the floor is too hot for the first pizza and it needs to be cooked closer to the entry where the floor will be a bit cooler. Subsequent pizzas can be pushed further in and the oven will hit its sweet spot, cooking 2 min pizzas for most of the night. However you must maintain a fire on the side to keep the temp up. Also a new oven still purges itself from moisture for several firings and you will find its performance improves for around 5 or 6 decent firings. The under floor moisture is the hardest and slowest to remove.
First pizza’s yesterday!
I was a little curious to see whether the oven crack would grow, but it looks like it didn’t.
I prepared 6 dough balls the evening before and let them rest in the fridge overnight.
After 90 mins the oven was at pizza temp, the first baked in 3 minutes, after the third pizza I noticed it took quite a lot longer and the dough didn’t rise as much with the crust less airy.
I was doing other stuff at the same time between the first and finishing the third was probably 25 minutes, in which time the flames had died out.
So I decided to move the coals to the other side and build back to flames so I could bake pizza’s at the other side where the floor would be a bit hotter.
The next three pizza’s were okay, but the first was still the best and since then I was always struggling to keep the oven floor at 350°C or above. I guess 90 minutes is just about okay, but it’s better to saturate the oven just a bit longer so the floor stays hot longer.
And/or I should also build my fire bigger with more coals.
I almost forgot to take a picture.
After that I baked 2 breads @ +/- 230°C (they browned really nice but taste only “meh”, still learning all the dough stuff.
@ around 180°C put in some BBQ ribs for an hour, then wrapped them in alu foil, and 2 hours later took them out. Juicy, soft and loose from the bone. Very nice.
One little question: how easy/difficult is it to damage the dome with tools like the pizza peel, brush,… when I tap the inside of the dome with my knuckle it has a very hollow sound (Duh!), sound fragile, but I know the dome is a very sturdy design. Still I try not to touch the dome when brushing the floor, moving the fire and wood around, or raking coals out.
Also: I am stoked (Ha!) about the way the vent/chimney works: 99% of the smoke when starting the fire goes through the chimney, I have no ugly black soot deposit whatsoever on the front of the oven. something I have seen in some other ovens and really wanted to avoid. So big thumbs up for David S and others from who I copieda large funneled vent.
(I use the top down fire method which also helps ignite the fire more efficiently)Last edited by Kris S; 06-21-2021, 01:40 AM.
Allright, thanks Dave, appreciate your feedback!
Apart from the bottom section I could indeed not fit a playing card into the crack.
Next weekend I plan our first pizza's, followed by some bread experimenting, finishing with slow meat roasting.
Hi Chris,
Any large refractory section is vulnerable to cracking, primarily because of the difference in thermal expansion. A one piece dome in particular, using wood as a fuel is particularly susceptible. For this reason most cast oven manufacturers offer their ovens in multi piece sections. This makes things more manageable and less weighty sections. For mobile ovens some manufacturers offer a single cast dome as they're less likely to have problems with road vibrations. When I first began to build ovens I used a single piece cast dome, but now produce a 3 piece dome. Unfortunately this requires much more work to create a mould, particularly if the sections are to be step joined. This is hardly worth the effort for a single cast oven, the simplicity of the single cast, in situ, over a sand mould has way more advantages. The single cast does however have a tendency to produce a crack, just like yours has, which runs vertically right opposite the oven mouth. This rarely gets any worse though, and the oven will not collapse.
The attached drawing shows where fine hairline cracks (you couldn't fit a playing card into them)have developed in my oven (14 years old and still working like a charm). Subsequently I redesigned my moulds and now cast them in 3 pieces with a step joint between the front and rear sections. The top section is quite a large diameter which allows it to get hotter and expand without stressing the other sections.
See top pic: one piece cast with hairline cracks
bottom pic: 3 section castings
I th ink you are over worrying, get into the joy of cooking
Dave
Well, I'm in need of a bit of reassurance (hopefully!) about the crack in my oven...
Upon closer inspection it seems the crack spans nearly the whole dome.
it starts at the bottom, right smack in the middle of the back wall staring me in the face, and is about 2mm wide, i guess.
it gets thinner the higher it gets and about 2/3 up it splits in two with both cracks going around in a square patch the size a of hand and then rejoin again. (I think the hand sized patch could be the same size as the lumps of homebrew I used to make the dome, so maybe it could have been the last lump of a batch which was maybe just a bit dryer than the rest?)
after that it seems there a thin hairline crack running the apex and joining a small crack which goes almost to the bottom again ending right of the entrance...
I tried to make a top view sketch.
Top marks. My Son in law says he’ll never roast a chicken another way. I like to sit the bird on a rack in the baking pan and add 1/2 cup of wine and half a cup of water. That protects the bird from the intense heat of the oven floor when it’s popped in, eliminates any burning of the juices and leaves the right amount of liquid in the pan to make the gravy easily.
