I did a diy steel WFO and I use 3.5” Rockwool insulation from Home Depot between the domes. Works great.
Welcome Dan!
There have been a few steel ovens - here's two I know of:
Steel Dome thermal mass question - Forno Bravo Forum: The Wood-Fired Oven Community
Low-mid mass stainless dome pizza oven build - Forno Bravo Forum: The Wood-Fired Oven Community
Kind regards and good luck!
Mark
Portable Steel Oven
Hi all,
I'm planning on making a portable steel WFO. I'm thinking barrel shaped is probably the way to go. I'm planning on using 10 gauge mild steel for pretty much everything, doing a dual layer design with ceramic fiber insulation between the two layers, but I really don't know much about oven design and couldn't find anything using the search function, so any links to resources or ideas in general would be really helpful.
Thanks,
Dan
