My "Earthy" Outdoor Kitchen Build
  • #46
    Re: My "Earthy" Outdoor Kitchen Build
    Coolness!
    Just a thought but maybe you could hammer the pipe flat where it connects to the pan. It would probably be easier (and safer) to drill.
    [/CENTER]
    • #47
      Clay Oven Update = Pending Disaster
      I guess getting the right mix of clay and sand is harder than I first thought.
      Over the course of using the oven, I have had bits or sand and clay fall in the oven, but nothing too serious.
      Well, that is going to change any day now.
      I have major cracks in my vent opening, and the chunks are loose. I'm sure it's going to fall if I bump or push on it. Oh well, I guess I'm glad I never got around to finishing my enclosure.
      So, I will be dismantling the enclosure, bagging up the loose Perlite, and destroying the clay dome. That part should be fun...I guess.
      The bricks are purchased, and the cutting has begun. I will start a new thread to chronicle my "new" brick oven build!
      Toby
      • #48
        Ouch - as someone just completing a clay oven build, this is somewhat disturbing!
        My Clay Oven build:
        http://www.fornobravo.com/forum/f43/...dah-12821.html
        • #49
          You clay mixture looks a little more scientific than mine. We simply mixed up a batch of Arizona clay (dug up in my yard) with sand and water, trying to keep a 75/25-60/40 sand to clay ratio.
          Toby
          • #50
            Um, you didn't use straw?
            [/CENTER]
            • #51
              Nope, I saw a few recipes with straw, but went a different way on mine.
              Toby
