Did you adjust the height of the door opening ?
If not I'd be really interested to see if/how it fires ?
the door opening height is almost 10", about 9.75 actually...
and the dome ended up at 17.25
63% of 17.25 is a 10.8675" door opening height, I am at about 56% 9.75" so basically i am about 1" too low. has anyone else been an inch off? i am curious to see if it will make a huge difference before i make any alterations.
I would be making sure that the dome sat on top of the floor rather than the floor inside the dome, otherwise your ratio will be out further. Some mortar between the dome and the floor will also help to get closer to the ideal ratio.
