Great job dude!! Did u manage to seperate the dome from the walls? ... or did u just leave the cast as a whole?
I haven't tried to seperate them, I think it may not seal back up as good as it is right now. Imay have to though when I go to mount it on the trailer...
Joey, which product did you go with from Wesco? They've got a ton of them listed. I'm probably going to be casting a dome in the next couple of weeks, and $19/bag is half what I've seen everywhere else.
Looking forward to seeing the completed pizza wagon you've got going there.
allright, I just removed the form boards for my refractory concrete insulating layer. I made it
2" thick. My bricks will go over this for my oven floor. I will let this base dry out a couple of days befre I set my bricks on top of it.
QUESTION:
should I mortar the bricks down or not?
I plan on welding a angle iron frame around the bricks so they will be in snug with or without the mortar.
(the little square tubings sticking up are coming off, they were there just to hold my form boards in place)
you do not need to mortar them down,, especially with the iron holding them in place, even if you get some that arent level, you can always grind or sand them down...
that is good top hear.
I tested the fit of the bricks to see how many would need to be cut and there is alot that will need to be cut, what is the best, non traditional way? (read=I don't own a wet cut tile saw and don't want to rent one...)
I also settled for a 36" floor height. I felt it would be ideal if I am sitting down checking on the pizza or fire.
What kind of insulating concrete did you use for the underfloor? It seems like 2 inches might not give very much insulation unless it is of a very high r-value material, like the insblock or FB board people here are using. The perlite-concrete insulating mixture from the pompeii ebook is recommended for 4+ inches.
