to light the dome is it possiable - Forno Bravo Forum: The Wood-Fired Oven Community
  • to light the dome is it possiable
    just got the go a head to start the dome
    thought i might try to light the dome
    thinking if i put a glass title / lens at the top
    with a sleeve then a lamp and socket at the top
    so i can change the lamp
    if it don't work i can go back and take it out and close up the dome
    Re: to light the dome is it possiable
    You might want to consider putting it in the side. The dome is the hottest part of the oven. Check out post # 43 on Re: 81 inch First Build under the commercial oven section.
    Seems like that may work.
    E
      Or you can get one of these:
        okay god point side it is then
        know to find the glass lens
        title
          olddude
          why not do as I did, mounted a couple of domestic down lights in my chimney void (as it is quite large) but I also mounted some plastic LED lights on Hendos oven outside the outer arch where the light is beamed into and across the oven opening. They work a treat and I wouldn't consider anything else.
          I have duplicated the pics from my Pompeii build to show the difference with the lights.
          They need a wipe with a moist cloth once a year, usually when cold.
          Cheers.
          Neillís Pompeiii #1
          Neillís kitchen underway
