accidentally coated inside 36" brick dome with high heat mortar cement
  • #16
    Re: accidentally coated inside 36" brick dome with high heat mortar cement
    done removing the mortar, now inside the dome has this rustic look
    not totally clean but tried my best, gaps are all filled for sure
    no more accidents for now
    again guys thank you
    jp
    • #17
      Iwood your location says Philippines what part?
      i grew up in ILOILO, now living here in fremont.
      • #18
        Good job fixing the mistake
        • #19
          I coat the inside of my ovens deliberately to produce a nice white surface. Pottery kilns are also frequently coated in this way too and they are fired way higher than we do. I don't think refractory mortar would be a good material though because the aggregate in it is way too course. I have never had flaking problems but the stuff needs to be applied to the surface when it is neither too damp or too dry.
