42" Oven - Forno Bravo Forum: The Wood-Fired Oven Community
42" Oven
  • 42" Oven
    Starting to build...using the Heat Stop 50.
    Re: 42" Oven
    Nice work, and just so you know we LOVE pron!!!
      Re: 42" Oven
      Looking nice - that part is the most fun (although it all is pretty fun). Enjoy!
      Pizza Oven Picture Gallery
        Re: 42" Oven
        Looks good.
          Re: 42" Oven
          starting on the arch openings and noticed that there are all sorts of different sizes. Since I'm doing a 42" oven (Tuscan style - higher dome), should I start the arch after my fourth brick on the sides, going up to the height of 12.5"? I noticed lots of people doing it after the third brick, but that starts at 7.5" and looks like it arches up another 2-3", so I'm assuming they're doing the lower domed ovens? Thanks for any help...
            Re: 42" Oven
            I started at the third brick with an opening of 12.5 inches. It gives me plenty of room to cook and gives the arch sufficient strength. My oven it 42 inches and the dome height is 21 (a little less due to the flatness of the plug). Hope this helps.
            Les...
              Re: 42" Oven
              Fourth course down...also started the base for the arches. Perfect weather for building.
                Re: 42" Oven
                Kihm said "pretty" as in pretty cute or pretty sexy.
                  Re: 42" Oven
                  Looking great so far.
                  Good to see you have taken the plunge and rebated your Openning/Inner arch.
                  It is fairly complex but worth the time spent
                  John
                  __________________
                  My Oven Thread:
                  http://www.fornobravo.com/forum/f8/j...-wfo-7911.html
                  The difference between a successful person and others is not the lack of strength, nor the lack of knowledge… but rather, the lack of will power.
                    Re: 42" Oven
                    Hey John,
                    Thanks. Have a question. What do rebating my opening/inner arch refer to?
                      Re: 42" Oven
                      I'm thinking about using splits on my inner arch. Has anyone else tried using splits? I was thinking it could help with smaller joints.
                        Re: 42" Oven
                        That must be Aussie for a reveal.
                          Re: 42" Oven
                          Splits vertically would work well.
                            Re: 42" Oven
                            Originally posted by doobie dee View Post
                            Hey John,
                            Hi Guys
                            Should have used the correct terminology, I meant reveal.
                            I use to be a cabinet maker hence the use of Rebating
                            John
                            __________________
                            My Oven Thread:
                              Re: 42" Oven
                              Just finished my first arch...pain in the boodie building the form but it worked out pretty well...I'll take the grinder to it when it hardens and smooth out the rough edges. I think I'm glad I used the splits.
                              I was starting on the next couple of courses when it started hailing on me...it's mid-June.
