Kenny's 36'' Pompeii in Scotland - Forno Bravo Forum: The Wood-Fired Oven Community
  • Kenny's 36'' Pompeii in Scotland
    Hi all,
    Finally got round to taking a few pics. Had a dry run with the floor and first couple of courses, cut half bricks using a hammer and chisel, will need a bit more finesse when it comes to smaller / more detailed cuts.
    Picasa Web Albums - 11336964747215976... - Pizza Oven Build
    When setting the floor level does it matter if I just use dry sand rather than fireclay/sand/water mix? Floor sitting on 4" of Vermicrete
    Made my indespensible tool today, next task is to discover how to post pics
    regards,
    Kenny
    Re: Kenny's 36'' Pompeii in Scotland
    for pics I would use a service like image shack, and when you upload let it resize them to 800,600 or something more forum friendly, then use .[img] tags arround the url it gives and bobs your uncle pictures in the thread
      1st attempt at adding a photo link....
      Picasa Web Albums - 11336964747215976... - Pizza build 1...
        I always add my photos by using the "Post reply" then "manage attachments" and select the photos by browse and upload.. This isn't working for you?
        Chris
          Another go!
            See if I can get them come out a bit bigger!
            First couple of courses in place
              Hurah!!
              Chris
                Inner arch pics, I used a wooden form and there is a triangle of brick hidden behind the mortar on the larger couple of joins.
                  No football today so made a little progress another course or two and starting to tie dome in with arch
                    Nice progress and good pics
                    All the best with the rest of your build
                    Terry
                    Honi soit qui mal y pense
                    My 2nd Pompeii build.....
                    http://www.fornobravo.com/forum/memb...eii-build.html
                      Nice weather today, another couple of courses done, had to pick up my 4th tub of readymix mortar, will likely need a 5th tub after the next course, bit of a pain as it's not cheap at ?32 a tub.
