Enclosing the dome - Forno Bravo Forum: The Wood-Fired Oven Community
Enclosing the dome
  • Enclosing the dome
    Do i need a vent of some sort to let heat escape when i build around the dome. I was thinking about using retaining wall blocks?
    Check out the vent description pages. The vent is outside and just above the oven door.
    http://fornobravo.com/pompeii_oven/vent.html
      I think you may be asking about venting the enclosure, not the oven itself. If so, I think you should have some sort of vent in the enclosure to let moisture out, not necessarily heat...
      My Oven Thread:
        Oooops. I can see that now.
        You don't have to. If you let your oven cure slowly, and moisture in the oven and insulation can escape gentlely. That said, I believe some builders have added vent.
        Any comments?
          Venting, errr
          NJ,
          The climate I live in is not a humid as yours, and certainly not in winter, but here's what I did. The upper portion of my oven is a 4 inch block enclosure, to which I attached facade bricks. To vent this enclosure, I used "brick vents" in the facade bricks, after leaving holes in the block walls. These vents are made of metal, and the shape and size of an ordinary brick. You can probably get them from a masonry supplier in your area. My cue was that dampness in insulation is not a good thing, nor is excessive heat. And, after all, you'll only do this once. For the "attic" in the roof over the oven, I used standard soffit vents, plus one directly above the oven door in the portico I built. If you need pics, I'll send. These are pretty standard house building procedures, so I figured why not.
          Cheers,
          Jim
            I have soffit vents
            Any comments?
            I have soffit vents in the overhang of my roof over the sides, plus a vent at the back vertex of the roof.
            As long as I can keep the bugs out, I'll be OK.
              Thank you all for your support and ideas.
