Is 2 inch of Insulfrax enough? - Forno Bravo Forum: The Wood-Fired Oven Community
  • Is 2 inch of Insulfrax enough?
    Hello
    The roof of my oven will be a brick half barrel/arch type.
    Unfortunately I have had to revist my original design and make the roof lower. This has impacted on the cavity between the dome and the roof. Making it 2 inch at the closest point.
    I have 2 rolls of 2 inch insulfrax that will cover the dome, then the voids will be filled with vermiculite.
    I was wondering if 2 inch of insulfrax will be enough to stop the heat transfering from the dome to the outer brick roof 'completely??
    If not, I am thinking of cutting the bricks in half (along the long edge) so I can get another layer of insulfrax (taking it up to 4 inch) at the closest point. It means more work, but I've invested soooo much time in it so far, it's not a problem
    Any advise will be appreciated.
    Mick
    Re: Is 2 inch of Insulfrax enough?
    What is the roof made out of? Combustible?
    I would think 2" is enough, but curious what the roof is made of.
    CB
    ____________________
    My 42" WFO/outdoor kitchen build thread:
    http://www.fornobravo.com/forum/f8/c...-us-13256.html
      Thanks for the reply
      I really hope it will be as it will save quite a bit of extra work.
      I'm finishing my roof like this:
      I'm not sure if this piccie will show. If not I'll sort another
      Mick
