Sydney Construction Has Started!!
  • #16
    Re: Sydney Construction Has Started!!
    Hey champ good luck this weekend take loads of pictures. Are you tapering your bricks?
    • #17
      No all the cutting I am going to do is halve each brick. The kit already had the door arch bricks cut with a taper to easily form the arch so I figure the less cutting the better. I am suppsed to have started already but I took my daughter to the coffee shop instead. I will get there eventually.
      • #18
        WooHoo the dome and door arch are done I will post some photos when I get into work on Monday.
        • #19
          well done!
          • #20
            OK so I was wrong about the cutting, man there was brick dust flying everywhere. I ended up cutting heaps of small pieces to fit gaps I am not sure I should have had.
            Here are a couple of photo's of how the work progressed.
            • #21
              • #22
                So I am going to finish of the flue arch and then tile the bench tops this week "hopefully" then I can render the dome so that the render sits on top of the tiles and it will have a nice smooth edge.
                Lets see how that goes.
                • #23
                  Well done that looks like a solid WFO!
                  • #24
                    Well brick arches are so much harder to cut than I could have imagined, its taken over a week just for this.
                    The problem was I decided to make the flue arch out of the same brick as the bas and hence it took days cutting and wreaking bricks to get the final batch and then to put them in place,,,,,,
                    Anyway just the chimney to go and then I can start on the finishing touches.
                    I ran a tape measure over the dimensions on the weekend and am wondering how my design will be to operate. here are the specs so far.
                    internal dome 1 meter
                    internal length to where the door will be 1.15 meters
                    lenght from back wall to outside of the Flue arch 1.72 meters
                    Door height 35cm
                    Door width 54 cm
                    Flue arch is a 34.5cm
                    It seems like this is a long way from the flue arch where you stand to the back of the oven?
                    • #25
                      We /Have Chimney!!! Plus the benches are tiled. Hopefully this weekend the insulation blanket and the render will be on and I will be cooking by mid Week!!!!
                      • #26
                        Well done mate!!!...... yep love the arch work wish I could lay bricks as good as that
                        regards cobbler dave brisbane Qld
                        • #27
                          Door height 35cm
                          Door width 54 cm
                          Wow, excellent work, looks fantastic. Your door is slightly bigger than the recommended but only just. Also your Flue arch is probably a bit longer than most, as most people use a half brick for the door seat rather than a full brick and then end up with two brick length for the Flue arch rather than 2 and half.
                          Looking great tho, and you are blasting through it. Looking forward to seeing the render go on.
                          • #28
                            It's been a while since I last jumped on but hey haven't you made progress!!
                            Looks great. have you also dropped a flue in or just brick work for the flue?
                            Again luv the colour of the bricks!!
                            Nearly there bet you can taste that pizza now!!!
                            cheers
                            John
                            __________________
                            My Oven Thread:
                            http://www.fornobravo.com/forum/f8/j...-wfo-7911.html
                            The difference between a successful person and others is not the lack of strength, nor the lack of knowledge… but rather, the lack of will power.
                            • #29
                              Ahhhhhhhhhhhhhhhh didn't get the render done over the weekend so my pizza is being delayed by another week.......
                              I got the fire blanket and mesh done but fell short of the render.
                              • #30
                                Oh I forgot to add that the reason I didn't get the render done was that I was finishing off the deck
