Thickness of Hearth - Forno Bravo Forum: The Wood-Fired Oven Community
Thickness of Hearth
  • Thickness of Hearth
    Hi,
    I've search for this but can't find anything, so just want to double check. Is 3.5" thick enough for the concrete hearth? It'll be reinforced with rebar and will have the fibre board on top + oven and housing. By my reckoning this could be:
    300 bricks for housing * 2.5kg = 750kg
    150 fire bricks for dome and floor (guess similar weight) = 275kg
    ? bricks for chimney (yet to be designed)
    So guess would want strength for 1.5t to be sure. Any thoughts? Have enough concrete to make it upto 5" thick if required (presumably the extra weight of the concrete is better rather than stressful on the bricks below?).
    George
    Re: Thickness of Hearth
    Originally posted by GeorgePalmer View Post
    Any thoughts?
    Its all about the span as to how thick the concrete is, the bigger the span the thicker it should be.
      It's 1.6m x 1.6m with a triangle (0.95x0.95x1.35) cut out the corner, for the classic corner design.
