Cloita's 42" Pompeii in Plainfield, IL - Forno Bravo Forum: The Wood-Fired Oven Community
  • Cloita's 42" Pompeii in Plainfield, IL
    Hello everyone, after about six months of reading and a few weeks of actually scouring the forums, I have finally started my oven. Our backyard concrete was poured in June and needed a good four weeks to cure. I took a four-day birthday weekend last week and got my start. My corner installation was inspired by Johnfm43's base so he gets first credit!
    Concrete going in:
    - Jonathan
    "If you don't know where you're going, you might not get there." --Yogi Berra
    Re: Cloita's 42" Pompeii in Plainfield, IL
    Base build Day 1 30JUL2011:
    - Jonathan
      Base build Day 2 01AUG2011:
      Next is the wood storage opening support and then on to course 4/5 and hearth! Thanks for all the great reading material and I look forward to finishing this oven!
      - Jonathan
        Excellent work, love the concrete look.. never seen that before..
        Any chance those pics can be put underneath eachother instead of side by side?
          Thanks. I'll think twice about that stamp design next time though, was hell getting that first course of bricks level.
          - Jonathan
            More progress!
            13AUG2011:
            - Jonathan
              ~10 more bricks on the inside then I'm ready for concrete/rebar and the hearth!
              21AUG2011:
              - Jonathan
                It's about that time of the season again in the midwest. Poured my hearth, cut my fiberboard, and started dry fitting the oven floor.
                - Jonathan
                  - Jonathan
                    Hi Colita,
                    I am doing a corner build too and about the same stage as you. Are you doing an enclosure or a dome? Still have not decided on whether to enclose or not but heading towards a dome style.
                    Beehiver
                      Grats on the progress! I'm planning on enclosure with a flagstone finish to go with the stamped concrete under the oven. Left about six inches each side to accommodate the framing and insulation, hopefully I did it right.
                      - Jonathan
                        Nice job on stamped concrete. Post progress pics. Working on jig for brick saw to cut taper/bevels on firebrick. Going to steal ideas from WFOs.
                        Thx,
                          Will do, good luck on the jig
                          - Jonathan
                            Lots of progress this weekend, for my pace anyway! Most of my floor is cut and dry fit and my soldiers are ready for mortar.
                            - Jonathan
                              Any tips for inside cuts like this with a stationary saw?? Failed a few times then gave up for the night. Been thinking hard about it and might go with a two-piece approach to eliminate the inside cuts.
                              - Jonathan
