May be starting my 42" Pompeii in NYC this week...
  • #31
    Re: May be starting my 42" Pompeii in NYC this week...
    Nice blast door Lee.
    • #32
      Broke ground for new slab in the last hour. Hoping to have it poured by the end of the day.
      • #33
        Question, once the slab is on, can I use a 4" layer of vermiculite with Portland as my base for the firebrick floor or do I need to get the FB board on top of the vermiculite first?
        • #34
          That is an either or. Vermiculite/ Portland cement OR FB board. You could do both but that would be over kill. Then you set your floor on top of whichever one you choose
          • #35
            Ok so I can go 4" slab then 4" V and then lay the floor right on it?
            • #36
              Almost ready to pour the slab. 8" thick with 6 36" pillars using 4000psi mix reinforced with rebar.
              • #37
                Added a 7th pillar for good measure.
                And 3 cubic yards later the slab is done.
                Tomorrow the cinder blocks go up.
                • #38
                  Some progress this morning.
                  • #39
                    Nice start NYC, I can tell already by your work you'll be glad you built one yourself. It's going to be nice. If you go with vermicrete as I did for your insulation, keep in mind a 2x4 form will only give you a shade over 3 inches thick. I was able to slide my form up after the initial few inches and put another inch and a half. I used a 5:1 ratio of vermiculite to portland which worked out well.
                    Leigh
                    • #40
                      What is the pipe for in your wood storage area?
                      • #41
                        Does the V need to Spanish the entire slab or just an area large enough to house the oven and landing since it is simply and inslating layer for the floor?
                        • #42
                          The pipe is a gas line from an old grill from before I built my kitchen in another area. It will be capped off and not be used.
                          • #43
                            OK, day 2 I finished the block stand and filled some of the corners. It started raining so I couldn't fill more. Next up is the forms and slab. I may have to get one of my guys to help so this moves faster. I spent two whole days and only got the slab and stand up.
                            • #44
                              OK, today I finished pouring the concrete in the blocks and got the rebar in them. I then made the form for the slab and tomorrow will pour the 4" supporting slab if the rain stops.
                              I also stucco'd the inside of the blocks with a water tight fiber reinforced resurfacer.
                              • #45
                                Looking good..
